The bolt that holds the bledd rail on the bottom right hand of the fuel pump sheared when i removed it. does any one know where i could get one or does any one have one i could have? the fuel pump is on my june 1958 fordson major diesel. i have some photos here .
http://s1201.photobucket.com/albums/bb3 ... to0317.jpg
http://s1201.photobucket.com/albums/bb3 ... to0319.jpg
help!!!! snapped fuel pump bolt
Re: help!!!! snapped fuel pump bolt
i broke one of those, but the top one.
Not sure you can get replacements, just get a bolt with the right thread to fit
The bolt is drilled as it for a leak off line on the bottom of the pump.
Ollie, the bolt should have a small tube attached for excess fuel to drain out of the pump.
You can see a part of it in this photo I believe.
Gman: 1959 Power Major
