Here I am again, looking for advice!
On the FSM that I'm working on, there is a breather on top of the rocker cover, but no corresponding port for it to go into the air cleaner, like the other FSM has.
Q. should it be routed into the air cleaner, or had some FSM's simply a hose down the side of the engine?
(I suppose it could have an air cleaner fitted from an older FM, where the  breather was routed into the manifold.)
Not had time yet to take off timing cover, to see what's wrong in there.
( Been haying, but it's a bit slow, with on average only two dry days in a row! still, got 115 acres baled in nice condition, and another 35 acres about fit.)
Other old FSM has done all the rotary raking.
Thanks in advance, for any answers.
Richard.
						Rocker cover breather question.
Breather should go to the air cleaner otherwise there is no through flow of air. The breather on the timing cover is to let clean air into the engine. It should have a little clean oil in the cup and work like the normal air cleaner.
