tsr102
northermajor
tsr102
Post by northermajor »
hi im thinking of buying a ransomes tsr102 plough to go on my 61 super major ,my question is do i need a special valve to turn it over or just plug in ? thanks any info apreshiated.
Re: tsr102
If you have the hydraulic turnover version you need a Double Acting Ram Valve. DAR Valves are a bit like hens teeth and rocking horse manure, they do not come on the market very often and make large sums of money. Be careful because one for the later tractor does not have the same porting although they look similar.
The valve you need also fits a Dexta and Super Dexta.
You can just see mine on Dotty to give you an idea on what it looks like.
