rocker link
gordon5a
rocker link
Post by gordon5a »
can anyone explain what the two different holes on the rocker for the top link are for, ie which one for ploughing and other ground engaging implements
Re: rocker link
Top one for increased sensitivity, bottom one for lower sensitivity of the lift in Draft control. Bottom one for ploughing unless wheel slip is a problem, top one can then be used.
Top one for light cultivation work like a spring tine harrow.
If using Position control it does not matter but I would tend to use the bottom hole.
