I cant get the old bushing out from inside the pedal any helP/ tips welcome
Dexta clutch bushing
Re: Dexta clutch bushing
Hi Dextas,
I had the same problem which was overcome with the use of handy small cold chisel, freshly sharpened.
Clutch pedal in the vice and then carefully cut a slit with the chisel across the internal face of the bush.
If you are lucky you might find the bush already has a manufactured split in it and it will collapse fairly quickly and drop out.
Regards, Jamie.
Regards, Jamie.
It was like that when I found it.... & I wish I had left it alone!
Thanks jamie i will let u mo how i get on
Finaly got it out i split it up the middle with the chisel and it just slid out thanks jamie
