My beloved 60's super major won't start. Its a long story, but I ran out of diesel, and after refueling, I bleed the air at the fuel filter. Couldn't find a bleeder at the injecter unit. Was turning over strong with the starter moter, but really didn't sound like any fuel was getting through. After all this I read maybe I needed a fully charged battery to get the fuel through the remaining line in the injectors (I could see diesel running smoothing out the bleeder at the fuel filter when manually pumping the lifter).
So I fully charged the 12v battery. Got a surprise when putting it back in as I figured out it is postively earthed (first vehicle for me like this), I am assuming this now from documentation and the fact my battery terminal clamp sizes for +/- fitted the battery this way round (them being one small and one big).
Problem is when I turn the ignition all I hear is a single Click. Should I put a cable from the Neg on the battery to the other side of the Solenoid to see if the Solenoid has somehow coincedentally died through all this?
Any suggestions would be welcome. As now my Fordson isn't starting, I miss it more than I could have imagined
Heath Macfarlane
New Zealand!
