Super Major L/H Brake Actuator Boss Removal
dave91
Post by dave91 »
Hi everyone,
Probably a very silly question but my 1961 Supers brakes dont release when the pedals are released. I have disassembled the R/H side and clean it all up, some of the linkage clevis pins were seized ect. Reassembled and adjusted all ok. Now I am doing the L/H side, all the clevis pins are seized and the clutch pedal needs a new bush. How do I remove the brake acutating boss (sits between the clutch pedal) to release the clutch pedal?
It looks like there is a pin in the centre of my brake boss, but I suspect it is a bolt with the head sheared off, am I correct? :cry:
Thanks.
Regards,
dave91
1961 Fordson Super Major Live Drive, 1964 Fordson NP Super Dexta Live Drive,
Ford Force 2000, 3000, 4000, 5000, & 7000.
liam
Re: Super Major L/H Brake Actuator Boss Removal
Post by liam »
It is a pin which you will have to drive out with a hammer and punch
AdrianNPMajor
Post by AdrianNPMajor »
Slotted roll pin. Can be a b*gger to get out due to rust.
Best
Adrian
