Morning, Does anyone know the amount of movement should be on the Power Major Clutch Release Arm (approx) before the thrust bearing picks up on the Clutch adjusters.
I was looking for the amount of movement of the Clutch Release Arm ( on dual clutch) not the pedal, as at the moment have no clutch pedal etc fitted on. As needs rebuilding as had about 6 " of free play
