Early major tacho clock
Hesford
Post by Hesford »
Hi all been wrestling with my tacho clock bracket for ages now and can't get him to fit does it go below the dash mounting bracket or in between the dash and the fuel tank?
Ash :shock:
1950 E27N Petrol/TVO
1956 New Major Mark1
fenhayman
Re: Early major tacho clock
Post by fenhayman »
Hesford,
I hope that I'm not talking out of the wrong end but I believe it sits to the throttle side of the dash and that the throttle lever was cranked to accommodate it.
Hesford
Post by Hesford »
Thanks for that :-) I wasn't sure if it was sure which way the bracket went with the bolt as in the bracket under the dash bracket then the fuel tank?
Don't know if this will help.
