simms minimec cold start
mark white
Post by mark white »
Hope you guys don't mind this question about my jcb?
Having had my 1972 jcb with the 4cly leyland engine for a while, I have looked at the poor starting. The previous owner had used ether as a cold start :cry:
I have cleaned all the fuel lines, new filters, flushed out the lift pump ( the filter screen is missing) . The rack moves freely from stop to max fuel.
I did press the cold start button once and it fired up like a major :wink:
The cold start button does not always work correctly tho , part throttle, engine stop in, and the button won't go in now!
It is a simms minimec similar to the majors, how easy is it to rectify the cold start button problem, does the pump need to be removed from the engine? How easy is it to retime, the pump bolts flush to the block.
If any one could post a picture of the cold start section of the pump that would be fantastic.
MARK WHITE, WESTBURY
Mervyn Spencer
Post by Mervyn Spencer »
Hi Mark
Just my two pence worth. Not so long ago it was mentioned on this forum that your throttle should be about a quarter open for the cold start button to remain in. I did try that on my Dexta simms pump and it definately remains in.
Hope someone else can confirm the above, good luck.
Mervyn
mark white
ye have tried that, but it's like there is something stopping the button from going in properly :(
Mark,
When the button won't go in try pulling the stop, pushing it forward then trying again. (Just diagnostic).
mark white
Ye, I have tried that too. :?
It seems strange it worked once but not again :?
