I've got an early e1a Major that I've got to fit a mill loader to, plus a trailer tipping pipe and I am in need of some diagrams or pictures as to where to run pipes off and to where,  I want to control the loader by a mono block type levers etc I am a little lost as to what to.
Any help would be much appreciated
Thank you
Ben
									Major loader
				Ben 26
- Contact:
Major loader
Ben Phillips
www.thetractorlad.co.uk
Re: Major loader
http://www.fordsontractorpages.nl/phpbb ... f=2&t=5568          http://www.fordsontractorpages.nl/phpbb ... f=2&t=2906        Hi Ben seen some of your work in t m  your question appears incomplete but i think the above links may have some answers. i would use a double acting control valve or supply block thou i understand there rare in the uk run that to a triple spool valve one of which  you either get a single acting spool for or run a dump pipe from the down side to the diff filler and use that one for the tipper pipe.  Also run the by pass or third line to dump there as well but the local hydraulic service wood advise on that  b
									1x 23f  1x 34 blue n 1 x 44 green n e27/s x 8 3ooo/ 5000 slectospeed  county 754 x1 ford k series truck
