tom lad wrote:what will u run it in ? position set to the lowest ? or quali ?
my MF mounted discs have baskets for more weight .
The Ransomes manual for this harrow, which is power matched for the Dexta, '..recommends Quali, but Posi can be used in some conditions..' It doesn't say which hole in the top link rocker. You suggest the lower less sensitive position?
See photos below of my 'new' harrow when I got it.
As you can see the front discs have taken a beating, particularly the RH ones. Rear discs are rather better, exc one's gone! But again more wear on the RH discs. I guess that Quali will protect the rear gang better than the front, as when the rear gang goes over a big rock, the Quali will lift the hydraulics. But if the front gang goes over a rock, the Quali will respond less.
Unlike my Weaving chain harrow, the disc harrow's headstock doesn't have a for&aft slot for the top link, just a hole, so there's no longitudinal flex between harrow and tractor. I'm thinking that I need to introduce some movement here. Given the harrow's narrow width, that's prob more important than introducing some roll float.
Which MF harrow are you using, how many discs, what's its weight. How does it cope on undulating ground?
It's worth mentioning that I'm advised that round here a trailed harrow copes better over rocks etc than mounted, because there's more flex, but trailed is a pain moving from field to field etc.
Comments appreciated!
