First posting from Bogside-on-Bure, have a 1958 E1A diesel Major s/n 1470163 which has been the family tractor since the early '60s, replacing a p/p E27N which had replaced a Standard - (still have one cast front and 2 rear steel spud wheels from this). Its about as original as can other than having been daubed with wrong paint and been used for ploughing cultivation, timber / stump clearance, haulage and sawing with a little road trailer work.
Its been out of use for a while and is gradually being put right, not having a lot of tlc for the last 20 yrs. So far fuel tank has been cleaned and sealed, painted so I guess technically restoration may have started although its intended use is to continue managing timber rather than for display. Rad hoses replaced and will start and run although cold start is needed both cold and when warmed up so obviously fuel or compression problem yet to resolve. A back tyre also needed, along with a non scalloped hub (we also had a Super which dad sold before he died, obviously went with the wrong wheel! having 2 scalloped and one JCB type wheel spare)
Got the V5 sorted before they closed the Norwich DVLA office but until I've done a bit more fieldwork testing what else might be wrong have not risked taken her out on the road. While not intending to rally, with Marsham & Skeyton fairly close I may have a run out later in the year.
Have been enjoying browsing past posts for others experiences and noted that there appears to be accurate build date info available somewhere which I have not as yet found - perhaps someone can either point me in the right direction for this, or if not public access, let me know when 1470163 was actually built, as I was also 'outshopped' in 1958, have been wondering if I or the Major is the older, its debatable which is in better condition
oehrick
 .. Over here we sip Moon Shine. Some is better than others, but after the second glass it really does not matter.
  wet it down at least twice every day for a month when you watered the lawn
   Dandy Dave!
  Dandy Dave!
