I am looking for an exhaust manifold for a Major Diesel.  From what I can tell this is a  March 1959 FPM .
The manifold has straight mounting holes.  I can't find it from any aftermarket dealers.
I'm on the US side of the pond so I may prefer options over here first but beggars can't be choosers.
Phil
						Wanted Exhaust Manifold FPM Straight Mount Holes
				BearCreek Majors
Re: Wanted Exhaust Manifold FPM Straight Mount Holes
http://www.tractorpartsasap.com/articles.asp?ID=134
They should have new and possably used ones. Google "Fordson major parts", there is Agraline, Import Tractor Parts, and several others. I get most all of my new parts shiped over from the UK.
Pat
Pat
Try eBay - there is a guy on there - goes buy username "Ivt21452" he may have one - and he is US - there are loads over here- seem to struggle to get rid - you can pick them up for as little as £10 ($16) !! Good luck with getting one
Thanks for the pointers folks.
Here's what I ran into. All States Ag is putting out the feelers for one and I haven't been able to find the user on ebay you listed Mjg1705. I have been searching Ebay but I don't seem to be getting the results that maybe you are. So if you see something over there that looks promising I'd appreciate a pointer and I'll help them get rid of it , maybe 2 at that price.
Phil
 , maybe 2 at that price.Phil
I know this is not what your after - but type this item number in to your eBay search - and then you will be able to see the eBay user name - you could give him a message - worth a try if you need one - 301082512285
Excellent.. I was able to see his listing for a manifold on ebay (actually had seen it before just wasn't sure I wanted it) so I sent a message..
Any chance there are shops in the UK that you could give me a pointer too. I'd really like to get a nicer or even new one if I can afford it.
That's good then, as regards to shops --- you have the obvios agriline, then Dunlop tractor parts, pockock tractors, mayhill tractors, the list goes on ! And the prices vary a lot !! See what you think -
