On this bearing you can see remains of chrome plating on the journals. It has a grease nipple and is supposed to be greased according to the original FR manual.
Unfortunately some of the other bearings are not in such good condition so I've been looking for a replacement bearing. However, the only replacement bearing I've found thus far is from Westlake see below. But it's a bit bigger, for a 1.1/8" axle, so unless I can find another orginal size bearing, looks like I'll have to use two of the larger bearings on one of the disc gangs.
Strangely these have no grease nipple and no evidence of chrome plating.
Should I fit a grease nipple and grease them, or are they meant to run dry?
BTW anyone know where I might find another bearing apart from Westlake?
