Ebro 470 fordson super major
Hi my name is Scott, I live in Ontario Canada. Im working on a Ebro 470 Tractor. I believe the main gear box is a fordson super major gear box. The Ebro has a 2 clutch disk clutch, i need the pto clutch input shaft. Did the fordson super major with two disk clutch use the same pto input shaft in all there gear boxes? and can you still buy this part?
Re: Ebro 470 fordson super major
Hi Scott,
According to the parts book it was the same input shaft from 1957 to end of production but there were changes to the other shafts around June 1963. Think you will be looking for a second hand one unless you can get one from Ebro.
