It's 20hrs since engine rebuild and after an afternoon's light work, she's developed an oily exhaust. Definitely oil, and the dip stick has gone down a bit.
hi , after i rebuilt my dexta i had 15/40 in her and afer about the same amount of hrs 25
iwas getting oil spots under bonnet, i then decided to change to morriss 30 stright ,
i have a small garden and i must have ploughed this up and then flatened it an reploughed must have
been about 20 times it did clear it up . try not to let her idle to much either, istll use the 30 stright
have about 300hrs on her and so far so good, sky blue
Thanks for the comments, especially about the oil. I see Morris's recommend SAE30 or SAE40 for 'lightly loaded diesel engines..where they can dramatically reduce the likelihood of bore glazing' . I'll get the old Robin plough out!
I've since put some Morris Running In Oil in her and after several days topping, there's much less oil coming out now. Been advised to leave it in for 100hrs.
