Sorry to hear how you lost your shoe and grille Adrian, not exactly lucky UNLESS it was due to be struck by lightning
I've got half a ton of the things here awaiting welding into things made of hosshoes but nothing quite that small.
Thanks for the masterclass in 'the old religion' DD,
perhaps you can give us the colonists take on lucky horseshoes, most indications are that they need to be a found shoe which has been cast by a horse, not one off a farriers pile.
But even here in NE Norfolk (where best estimates are that we are approaching, not with any degree of urgency, 1987!) there are two schools of thought about fitting a shoe for luck, one that it is open side up, t'other that it is open side down. My investigations indicate that open up is traditionally Norfolk, where at least a couple of nails or some baler twine is needed to fit and that open down has crept in from darkest Suffolk where hanging it on an existing nail is plenty good enough on the way to the pub, 'course then the fenlanders confuse matters even more, sitting on the fence they mount theirs sideways which leads to the silt fen / peat fen arguments of left or right pointing............
True story (have you come across this DD?) regarding George H Corliss, major manufacturer of American stationary steam engines in pre mild steel days, kept a stockpile of around 1000 tons of used horseshoes in his yard, obtained by supplying new rolled wrought bar in a weight for weight exchange with smiths / farriers all over the States. When asked how it made any sense doing this he explained that to make stress bearing parts of engines, conrods, crankshafts etc. they had to heat and hammer, heat and hammer, heat and hammer tons of new metal to get the slag out of it and to get the right grain texture refined for use and just how expensive this was to do, whereas all he had to do was to issue new metal at the same raw cost and right across America people, horses & mules were refining it by hand & hoof, bit by bit at no cost to Corliss, all he had to do was pile it, heat it and knock it out under the steam hammer
Clever chap !
