Sorry for this post...
I have to charge the battery of my recently acquired Power Major. I can't tell if its a sealed or open type though. I've looked for info on the battery but drawn a blank so I'm hoping someone will be able to help me.
The battery is a New Holland. Part No 643, 640 amp, 96AH dated 1/8/11.
Although the top is flush there are plugs in it which look like they could be opened using a very wide screwdriver or large coin. However they are very hard to get loose (i've tried a little to no avail). Each plug has MFG stamped on them. As I've just worked out how to add a photo, I've done just that below!
Does anyone know if I should attempt to undo 1 (or more?) before charging? And if so, confirm that I can/should add electrolyte if the levels are low?
Thank you.
