Hi Everybody,
What is an acceptable length of time for the Super major lift to drop from full up to full down with a transport box (with approx. 250 kgs in it) and with the engine switched off. Mine takes about 45 minutes. I think this is a bit quick, otherwise my lift works perfectly and has great lifting power. All seals have been renewed in the lift.
Regards, Liam.
Super Major Hydralic Lift Rate of Drop
Stu_Fletch
Re: Super Major Hydralic Lift Rate of Drop
To be honest that's perfectly acceptable I can understand you might have hoped it was better with new seals, I'm assuming on your super has got draft control and the guidelines for acceptable corrections in a minute is 3/min with a set weight. It's noted more accurately than my memory in the service manual.
Stuart Fletcher aka Fletch - 27 - Leicestershire in the UK
1955 Diesel Major - Ford 2701E engine
Ford 4100 Bubble Cab
1996 New Holland 7740 SLDP 4wd & loader
hi that seems ok the lift isnt supose to stay up for long peroids when not in use
it isnt good for the seals for lift to remain in raised position with engine off,
and can be dangerous
as long it doesnt drop with engine running an does its job you have nothing to worry about
Thanks for the replies fellas,The lift is set as per the instructions on this site and it works perfect and does not correct itself at all with a load on the arms.At the moment I am getting it ready for a respray.Liam.
AdrianNPMajor
Hi Liam
My Super corrects half a dozen times in two minutes with a Ransomes TS 102 on the back, and it will go from fully raised to being on the ground in the course of a day or so. All this after getting new seals and a new unloading valve plug, which had been leaking badly, causing the hydraulics to correct constantly with the plough on the back.
Oh, by the way ..........
Would be great to see some before and after respray pics.
Best
Adrian
Best
Adrian
Hi Adrian ,I will get my wife to put on some pictures as I am not to good at this computer stuff,will try and get them on in the next few days .Liam.
