Check Chain Bolt size
Does anyone know the size / thread of the bolts that hold the inner check chain brackets around the pto casting? I have some new ones to fit so need to get new bolts and correct tap as the threads needs cleaning cutting having been left open for years.
Re: Check Chain Bolt size
According to the Parts List, it's 7/16"-14tpi (ie UNC) x 1.1/2" long.agroman wrote:Does anyone know the size / thread of the bolts that hold the inner check chain brackets around the pto casting? I have some new ones to fit so need to get new bolts and correct tap as the threads needs cleaning cutting having been left open for years.
Parts List is a good thing to have, not infallible but pretty useful.
