i am a new here. I run in a problem two of my pushbars for my valves are bend and i do need new one. i have no idea where i get them and the local dealer (new holland) tried to help me but to find proper part i do need find some information about my tractor (age) and motor.
i found a few no on my tractor but i dont have no idea how to read them.
thats the no i found:
on my injector pump: SPE 4A 75s647
left under injector pumo on motor : EIADKN6015
T3
Under the seat: EIADDN 501
and left side close to jont motor and transmision: D61d (but the first D looks back to the front)
Hope does anyone can help me or give me more ideas where i can find more information about my tractor or where i can finde more numbers on the tractor soi can order the right parts.
thanks a lot allready
Help with serial number and age
Re: Help with serial number and age
Look here... http://www.fordsontractorpages.nl/manua ... _major.pdf Dandy Dave!
thanks for the link.
there are two more spots to look. but how can i read the numbers the letter number code? what does the numbers mean which i allready found?
i looked into some post but maybe i mist the one with the decoding
After reading diffrent posts i found some nr on my tractor but i still have trouble to decode them to a proper Date.
This is what i found:
on my is telling me Fordson Super Major
under injector: EIADKN6015 E
under it little left T3
near clutch link (look up side down): P19(8?)D (think so look it right)
Near generator: A6F
under seat EIDDN 501
on my injector pump: SPE 4A 75S647
hope anyone can help me out to find a age from my tractor with all this codes
Near generator: A6F
Hello 6k. The numbers you list look like part numbers and casting codes, not serial number. Look at Dave's picture as to where the serial number is on your tractor. A picture of your tractor would help. Look at the home page on this site, bottom left and there are listings of numbers, manuals etc. Good luck.
Gman: 1959 Power Major
It will help you to find the important serial numbers by looking for numbers that have been STAMPED onto a machined surface [usually above the starter motor or near the injectors] and not the raised casting numbers and letters.
Finaly i found a number behinde the injector pump.
hope read it right : 1585931
i tried to match it with some of this lists but i could not.
hope some can help me i can try to make a pic from it if that help.
chriss
Could be jan 1961
Thanks.
I think thats bring me closer to my push rods
