Gruffydd
super major steering box
gruffydd
- Contact:
hi ive been looking for a steering box for my super major and seen a diesel major steering box i know the throttle rod isnt on the steering box but can i swap the casing over from my super steering box or will it not work ? thank you
Gruffydd
Gruffydd
dexta 1958
super dexta 1962
super dexta NP
super major
fordson dexta with NP backend
fordson dexta live drive
super dexta 1962
super dexta NP
super major
Re: super major steering box
Hi well I'm relatively new at rebuilding fordsons but I have learnt that the stering Colm is longer on the hand throttle type to allow for it to travel through the clocks . I do think that they are interchangeable
Paudie
Paudie
As far as I can make out from my book of words; you can -- with the only difference in the box itself being the oil seal in the drop arm side of the box having an O ring on early models rather than an oil seal proper as on later ones.
gruffydd
- Contact:
ok thank you everyone i think ill buy it and let you know how i get on at least then ill be able to move it about
dexta 1958
super dexta 1962
super dexta NP
super major
super dexta 1962
super dexta NP
super major
BearCreek Majors
As Paudie pointed out, the steering shaft and housing are longer on the Power & Super majors, if you have to take it apart to swap these parts you may be farther ahead to just pull yours apart and rebuild it. there are several vendors that have the parts available.........Just a thought.
Pat
Pat
gruffydd
- Contact:
hi pat yeah only thing is the worm is too worn too be re used and the thread where the arm is has been cross threaded so dont think i could re use the unit so ill have to buy a whole one does anyone have a super/power steering box for sale as id like to get it going soon
dexta 1958
super dexta 1962
super dexta NP
super major
super dexta 1962
super dexta NP
super major
gruffydd
- Contact:
dexta 1958
super dexta 1962
super dexta NP
super major
super dexta 1962
super dexta NP
super major
