It had two cylinders with a piston connected to a flywheel that pushed water up one cylinder then the other on the return stroke. Gas was introduced in the space between the water and the cylinder head which was then ignited. The expansion then pushed the water down the cylinder, acted on the piston which pushed the water into the second cylinder, compressing the gas and this was then fired.
Water lost by being turned into steam and ejected through the exhaust was replaced by an ingenious system of valves.
Just think of it though. No pistons, no rings, no big and little ends just water!
No need to worry about using ether in Dexta's in cold weather either. Would have to have lots of antifreeze though.
