https://www.youtube.com/watch?v=syQAVqJz4kE
So the dynamometer is used in my job as a very valuable tool to help diagnosing faults mainly on the engine whereby the way a/any load can be put on the engine in a safe environment where you can assess the performance of the engine (hp) and torque, the fuel system including running pressures, the cooling system can be tested at the engines working limit to check it is up to the job of keeping it cool, the electrical system including solenoids and sensors on newer engines sometimes need to be hot or under full load to replicate a fault impossible to diagnose in the field, and it is also a good way of checking for leaks as when the engine is up to full operating temperature all the fluids become much thinner and can appear when regular use could take hours weeks months for the leak to start sweating out.
I have never even spotted a weep coming from the head gasket on the \r/h side behind the injection pump which has shown up today.
All of these things can be monitored with gauges etc whilst the engine is under any load you enter into the dynamometer.
Now the dynamometer is quite a simple machine the is a set of PTO shafts to suit any tractor which basically connect your tractor whether running at 540rpm or 1000rpm to a generator, now to put a load onto the tractor through the pto is a huge bank of electrical elements being cooled by a fan driven from a 13amp 230v power socket. To load the tractor you simply use the controller to increase or decrease the load and can be set to keep it at a continuous rpm automatically and it can bet set infinetley from idle to the tractors max rpm say if you wanted to leave a tractor on it to run the engine in whilst you left it to tidy up etc. This is particularly handy as newer tractors are fitted with hydraulic and elctronic ECU controlled viscous couplings on the fan which basically lets it slip and slow down to save fuel consumption and power loss when the air leaving the radiator is cool and it then locks it in when the air leaving the radiator is hot to drive the fan at full speed to keep the engine cool - this draw in power as the fan cuts in hard can draw up to around 20hp on a 200hp+ tractor which if left with a manual load on the tractor could stall it.
The test you can see I carried out was an auto test which just gives you a performance readout/printout through the entire rev range.
Another useful reason to use it is if you have an engine that rarely gets worked hard it can glaze the bores of the cylinders and cause heavy breathing, poor starting and low power due to a lack of compression, a run on the dynamometer can break this glazing and reseal the piston rings to save a big labour intensive strip down and rebuild even if now new parts were fitted.
The particular reason I had my injection pump reconditioned was because whilst in work the engine surged as if it was hunting although I knew the fault wasn't before the injection pump, the last time I used it on the dynamometer the engine surged on any load 3-45hp load until it was under full load now it hold the rpm perfectly and consistently through the rev range
Sorry that was a bit long winded but I hope that covers everything if there's anything I've missed i'm here to help
