Tombstone
woodcutter
Tombstone
Post by woodcutter »
Hi all does any one no the size of the four bolt holes in front tombstone of new performance major I thought they were 3/4 unc so I bought some but they seem a fraction to big they go about one thread and stop the threads could probably do with clean any help appreciated
frode
Re: Tombstone
Post by frode »
If they have not been used before, I would run a tap through them to clean out 50 years of dirt :-)
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
woodcutter
Re: Tombstone
Is 3/4 unc correct size as I'm going to bolt suppliers tomorrow I could also do with knowing what size bolts hold the toolbox to side of engine, cheers
Kjetil
Re: Tombstone
Post by Kjetil »
3/4 UNC is supposed to be the right size.
Clean the treads.
If you are using galvanic bolts, they may also create friction
Kjetil
BearCreek Majors
Re: Tombstone
Post by BearCreek Majors »
I had to make a new stud to mount my Super 6 weight last week, 3/4-10 UNC. If I remember correctly the Tool box bolts are 7/16 UNC.
Pat
woodcutter
Re: Tombstone
I've been and bought a 3/4 tap I tried cutting slots in an old bolt it did go in but didn't do a good job, I've been fabricating a large storage box to fit on front of tombstone cheers for replys
Kjetil
Re: Tombstone
Post by Kjetil »
I have seen Tombstones probably not made by Fordson
Can you have a non original one?
supermajor61
Re: Tombstone
Post by supermajor61 »
Have just tapped out 54 years of crud from the Tombstone. Used a plug tap 3/4" - 10 tpi UNC.
The depth of the hole in the tombstone is 1 1/2" deep.
The problem now is to find four 3/4" unc bolts, 1 3/4" or 2" long.
The internet offers me expensive Stainless steel bolts , or bolts from the USA with about $30 shipping charge.
Anybody know of a British supplier, preferably one who will post ?
Re: Tombstone
Try your local CNH dealer. Our has them all in store and not expensive
Daves rusty bits
Re: Tombstone
Post by Daves rusty bits »
Wentin Fasteners in Yeovil stock most UNC / UNF nuts and bolts , have posted out to me before and are reasonably priced. Sounds almost like I own the business doesn`t it ?, but I don`t, just like to support them Dave
Re: Tombstone
I've already mentioned elsewhere it's not UNC, it's BSW. Both are 3/4"-10, but the minor diameter of the Whitworth is smaller. a 3/4" BSW bolt will fit a 3/4" UNC nut but will fail easily, the reverse isn't possible. You can confirm this in any Ford publication (repair manual or parts book).
