Bonnet
58vintage
Bonnet
Post by 58vintage »
Morning all,
I'm guessing it will but in case I'm wrong. Will a super major bonnet fit a 1958 power major and line up all nice?
BearCreek Majors
Re: Bonnet
Post by BearCreek Majors »
Yup, basically the same bonnet with different holes for the badging.
Pat
58vintage
Re: Bonnet
Post by 58vintage »
BearCreek Majors wrote:Yup, basically the same bonnet with different holes for the badging.
Pat
Great. Thanks for that. Thought they all looked the same but thought I better check.
James.
fenhayman
Re: Bonnet
Post by fenhayman »
Check the exhaust position. Some were positioned outside the bonnet, others had holes in bonnet for pipe (Loader fitted)
58vintage
Re: Bonnet
Post by 58vintage »
fenhayman wrote:Check the exhaust position. Some were positioned outside the bonnet, others had holes in bonnet for pipe (Loader fitted)
The bonnet I'm replacing has the exhaust pipe outside the bonnet and the new super major bonnet I've been offered only has a hole for the air cleaner. It should fit then?
fenhayman
Re: Bonnet
Post by fenhayman »
As far as the exhaust pipe position goes - yes.
