Grani,
Is that Cat 1 or Cat 2 linkage? I am wondering if that would fit behind the petrol Dexta.
Somewhere I have seen some pictures of ploughing in the polder with two 200hp tractors on a single furrow plough, ploughing about 1.5 to 2m deep to mix tyhe lower clay with the top soil.
I've just watched the video of the big plow in Finland. WOW!
BUT From a safety aspect I wouldn't go anywhere near a wire rope under tension. If that rope was to snap then it will be like a whiplash and quite capable of taking off a head!!
Lets please respect some common sense safety here, that was an accident waiting to happen being so close and as for walking underneath, No way.
I was taught some recovery training in the Army and wire ropes are so unforgiving.
Grani,
I've operated Caterpillar's with swamp pads on the tracks before, they will go where the other tracks won't even think about going. If you want to feel something powerful under your feet you need to sit in the seat of a Cat D11R.
I've never seen a plough this big before. Now we have excavators to do this kind of work.
Thanks for that video, Grani. I used to run a Cat just like that one, but without the enclosed cab and wide tracks. I pulled logs with it, instead of a plow. I have pulled a big V-plow in the woods before with another Cat. It made furrows to plant trees in. Is that what that one is doing?
JC wrote:Thanks for that video, Grani. I used to run a Cat just like that one, but without the enclosed cab and wide tracks. I pulled logs with it, instead of a plow. I have pulled a big V-plow in the woods before with another Cat. It made furrows to plant trees in. Is that what that one is doing?
They make ditches with it to drain the forrest. It was not a good method because the ditch did not last for very long as the dirt fell back gradually. The dirt was only forced to the sidewalls of the ditch and not moved away as when digging with an excavator. An other disadvantage was that the bottom of the ditch was on the same deep from the surface all the way and the water did not flow right.
