Hi All,
Does anyone know where I can buy a starter motor bendix gear for my Dexta, looks like it maybe broke a gear tooth and then stripped the rest, it is the original push lever to engage type starter motor.
Bob
Starter Motor Bendix
Re: Starter Motor Bendix
Hello Bob
I doubt that you could buy the pinion for your starter, you will have to replace it. There are various breakers around if you don't want a new one. Just to be pedantic, the Dexta has a manually pre engaged starter so it doesn't have a Bendix. With a Bendix, the pinion gear is engaged by screwing its self along a spiral due its inertia when the motor starts suddenly.
Hope you get sorted out.
Ian
Ian
Hi All,
An update on the starter pinion gear (not Bendix), after much internet searching I found this http://woodauto.com/Component.aspx?Ref=SDV31032, spoke to the company and after much measuring and e mailing back and forth we decided that this was a replacement for the original pinion gear and clutch mechanism, the part arrived today, fitted and all now working again.
Hope this is of help to anyone else who has or will suffer from the same problem.
Bob
Bob
Well you learn something everyday, your persistence reaped rewards, well done and glad it's fixed.bobfaecullen wrote:replacement for the original pinion gear and clutch mechanism, the part arrived today
Ian
