I've encountered a problem. The aperture of the drive in the minimec pump is blocked with what I assume is the end of an old core that snapped off.
I've never worked on the minimec (or any injection pump, for that matter), and the repair manual is not very informative in this area, so I would be grateful for advice on how to clear the blockage.
In particular, I'd like to know how the proofmeter drive, held in position by two bolts, picks up its drive from the cam shaft. Is the proofmeter drive removable?
Thanks in advance.
Best, Adrian.
