New member, old tractor, where to put fluids?
Galoot
Post by Galoot »
Sorry, I don't know if this is a New Major or Major tractor. My brother has it, it belonged to our late male parental unit.
My brother is trying to get it working well and tried putting fluids in for the transmission. He had 5 gallons of "tractor fluid"and put some in what he thought was the transmission fill port. The dipstick a few inches away shows nothing even though he filled to the top.
Where are the fill points on this tractor?
I'll try to link to the few pictures I have of this tractor. The front photo is just to ID what kind of tractor it is.
Side view Image
Side of transmission Image
View in back of tractor seat Image
whirly
Re: New member, old tractor, where to put fluids?
Post by whirly »
First ... Welcome!
Your pics didn't show up but it sounds like you have a Major (52-64) ... but I could be wrong.
Engine, Transmission and Rear End ALL use S.A.E. 20W/30W HD for temperatures -7C and above.
Engine Oil Grades for Fordson Major all models.
-18C to –7C … S.A.E. 10 HD or S.A.E.10W HD
-7 to32C … S.A.E 20 HD or S.A.E. 20W/30W HD
over 32C … S.A.E. 20HD or S.A.E.20W/30W HD
Note: I can't find 20w/30HD so I use Delco 15W/40
Gearbox and Rear Axle Oil Specifications. All Models.
Service letter July 1959 states: Gearbox, Rear Axle and Hydraulics oil specifications have changed. Now all models from 1952 onwards use:
S.A.E 30HD or S.A.E. 20W/30W in all the above at all temperatures.
Power Steering uses 10W
Oil Capacities.
Engine .. 7 qts
Filter .. 1 qt
Minimec pump (when fitted) .. 5 oz
Gearbox w/PTO .. 5.5 gal 21.6 qts
Fill gearbox at filler near clutch pedal. Oil level marked on outside of filler.
Rear axle .. 10.8 gal 43.2 qts
Fill rear axle at filler plug behind seat. Oil level on dipstick near main gear lever.
Hope this helps.
'59 Power Major
Ancient Smurf
Pictures don't show up. The dipstick is used to check the level in the back end. The filler plug is located at the rear.
The transmission needs to be filled up almost to the top. There's a thead on the forum with the oil specifications
Galoot
Post by Galoot »
blackbob
Post by blackbob »
Hello and welcome, Galoot (a good Scottish name - whereabouts in the world are you?)
I can't really add anything to whirly's post, except to say that now we've seen the photos, I'd guess it is of similar age to mine, about 1957-8.
Presumably the yellow framework is for a snowplough?
1440276 - 1957 - working
1335674 - err - one day..
Ford 7710 2wd, 1983 - working
Galoot
Post by Galoot »
Thanks for the welcome! I sent the link for this discussion to my brother and read it to him, he seems satisfied that he has enough information to proceed.
I never realized Galoot was Scottish! I'm in California and the name comes from a hand-tool woodworker mailing list that I joined back in the late 90's.
The yellow frame isn't for a snowplow, but something similar, for pushing stuff around a farm field. I don't remember what my brother called the thing.
blackbob
Post by blackbob »
:oops: It seems Galoot is indeed an American word, adopted by some Scots (I haven't heard many people use it) possibly via the Navy? http://www.wordorigins.org/index.php/si ... ts/galoot/
I've never been to the US but I'm interested in all agriculture, and I was reading this the other day, and I wonder if your snowplow/dozer/whatever it was, was used to make levees (ridges) in the fields for irrigation purposes? http://talk.newagtalk.com/forums/thread ... 1#M5742865
(Being an American forum they do things differently, if you go to the top-right corner and change 'Threaded' to 'Flat' it makes it much easier to read)
whirly
Post by whirly »
Just an additional piece of info for you:
OK ... I can't spell either :oops:
'59 Power Major
Ancient Smurf
whirly wrote:Just an additional piece of info for you:
Did a super have this type of lift?
blackbob
Post by blackbob »
I wouldn't have thought so...
I can see why it could be a Power, because it looks to have a dashboard under the steering-wheel.. But it also has instruments (and, I think, throttle lever) low-down, like the older models - and I would think they are more likely to be original than the higher dashboard?
Galoot
Post by Galoot »
I'm at my brother's place again today, he said that the yellow frame is for a "brush hog" which is for clearing brush from a field. So much like a snowplow.
We bought 5 more gallons of lubricant, he's going to fill 'er up later today and see how it all works. I can take/post more pictures to help ID the beast if you want me to. We just want to get it running and use it!
