Water in engine oil
				stephen bendall
Water in engine oil
We have just had new liners fitted into the block of our major scraper tractor,although fitted in with heamatite red,the problem has returned, the man who did the work doubts if the water is going past the repairs, any ideas and anwsers please
									stephen bendall
				Mike Kuscher
Hi Stephen and welcome to the site.
So, you were showing water in the oil, got somebody to fit new liners but, having done that, you still show water in the oil ?
If he's right, then he did not 'repair' the problem in the first place.
If he's wrong, well, someone's just 'shot themselves in the foot' in my book
There are a few possibilities here that need to be worked through but, here's a few more questions for us all to start with.
a) Major, what year/serial number ? (just for interest)
b) Water in the oil but, any oil in the water ? (radiator)
c) Only new liners or any other work ?
d) Red Hermatite, semi-setting gasket sealant. Supposed to be used as a thin smear. How was it used to seal the liners ?
e) When the liners were out, was the block checked for cracks etc ?
f) Were new seals fitted to the liners ?
g) Were the sealing grooves in the block, for the seals corroded or cracked away and, if so, how were they built up ?
h) Is the top of the block flat, or distorted ?
i) Cylinder head properly tourqued down so that new head gasket not leaking ?
j) Cylinder head flat and not cracked ?
The more infromation and symptoms you can give, the quicker and easier the guys will diagnose the problem.
One thing is sure, I'm afraid, you've got some dismanteling to do.
Mike
Ooh! What a dangerous statement to makethe man who did the work doubts if the water is going past the repairs
Mike
				stephen bendall
water in engine oil
thanks for  the replies to my post                                                  1)serial no.1549405 according to the number on the block,and the registration document        2) the man who put in the new liners said to use some ironised heavy duty block sealer to see if that cures the problem,we did this friday, and could see no oil in the water,i dont think any of you are going to be impressed with the block sealer,  but it would help if we can keep the tractor going until turnout as we have to scrape  a building our 4000 wont go under                                                   3) liners, pistons, rings, valves, block and head machining also block was acid bathed, resprayed in empire blue, also new shells and main bearings,crnkshaft polished  020 bearings used but could have possibly taken 030        4)hermatite application was very generous but i thought no more about it as we had been told we could put fibre glass hardener around the base of the liners                                                             5)no 2 liner grooves were corroded our man talked about using lead but i dont think this was done ,if grooves need to be re built ,how? and best by whom?                                                          6)we have changed the head gasket as first port of call ,now the block sealer ,when we first stripped down no 2 liner just came out ,on this occasion we didnt find any corrosion holes in any liner last time 1995/6 i think no 2 had the liner hole                                  many thanks stephen
									stephen bendall
