Does anyone have a source for gasket sets? I have made quite a few over the years but
never started with one that was complete so just guess where the internal holes should
be.
Thanks in advance
Miles
Saskatchewan, Canada
Petrol Carb Gasket Set
AdrianNPMajor
Re: Petrol Carb Gasket Set
Hello Miles
Very sorry but I cannot help with this.
Posting this reply to ask for photos of your petrol Major. Would love to see it.
Best, Adrian.
Best, Adrian.
oehrick
Hi Miles
Can't help with a source but if you have to make one from gasket sheet I generally start with the screwholes by piercing with a small screwdriver or nail then use a sharpened pencil or wooden dowel pressed and twirled into the hole to make the right sized hole, fit a screw and work your way round, then lightly oil or dust with graphite the surfaces between and cut them with nail scissors, made several for Landrovers over the years and while a bit fiddly if you are careful you should manage OK you can cut the outside edges with a craft knife & steel rule if looks matters !
One of the handiest aids for this sort of thing is a set of cork / bung borers as used in chemistry labs, or make them by turning tube down to a shaop edge if you have access to a lathe.
The usual tapping round the edges with a small ball pein hammer is probably asking for trouble with a diecasting that age
Good luck finding a gasket set, or making them if the forces of luck are against you.
