Brian wrote:Hi Mathias, neither of the arrows are right, your confusion is because you have the lift on its back. The top stop is the little "bent in " tag which your sliding stop is up against at the "bottom" of the quadrant in your picture. (if that makes sense)
Thanks Brian, I think it's hard to see, but the red one is near the bent in stop. This is all for the quality control setting: The wiki says to raise the control lever to within ½” (13mm) of top quadrant stop. So this is untill hitting the "little bent" and then go back down ½”. The repair manuals (section of the new super major supplement) says to bring it above this little bent. a 0,010" feelerblade is then used between the plunger and the rear inner face of the casting
Is this just another way to Rome?
So far I've done:
turnbuckle will need some cleaning:
old piston seal off
new piston seal mounted
found lots of dirt inside the housing, I'm wondering if this might be 50 years old dirt
I needed to cut one of the spacers as it was rusted to the shaft.
Tried to weld it as good as possible
