Drawbar carrier
billy
Drawbar carrier
Post by billy »
Hi guys,
I'm near the end of my restoration, and I'm looking for measurements for the drawbar carrier pin. So this is the long one that is under the back axle. I believe it has a groove in it for locking. Not sure if I massively like that design but still.
When the tractor came to me, it had a thin bit of threaded bar through...not sure that would met the load specs?! :lol:
Thanks!
Re: Drawbar carrier
Billy,
this is the pin you are looking for:
Thickness is about 24mm, but you can check it on your bracket. The little plate is used to lock the pin in the groove and is bolt on the side of the drawbar.
Roadless63
Re: Drawbar carrier
Post by Roadless63 »
Ive got one of these with the locking plate, drop me a PM if interested. Regards, Ed
