although the lift arms on my 1959 Dexta have worked ok they have clearly been bodged over the years and I have:
- Bolts running through both top linkage knuckles instead of clevis pins
- Instead of a bush there is a huge what looks like a trailer pin holding the rocker bracket to the rear axle which is jammed in solid
- The paint on one of the arm assemblies has worn off revealing yellow paint i.e. what now looks to be an 'industrial model' part?
I ordered what I thought are new clevis pins from Agriline (part no. 4126) as the local agricultural place is a distributor but these don't fit through the knuckles (inserted left to right not back to front) as they are slightly too wide which may explain the large bolts. Is there a reason these clevis pins don't fit?
Just as an aside I also ordered a new rocker bush but they sent a complete rocker (part number 4213 - if you enter this into Agriline's search it brings up the bush as a search result but I just noticed it calls it 5459 which is where I went wrong as the Agriline search is a bit wonky.
How on earth do I get that big trailer pin out of the rocker - should I cut my losses and cut the damn thing off and replace the rocker?
Have I got the part number wrong for the clevis pins?
