New Performance Super Major raised PTO shaft
Roadless63
Post by Roadless63 »
I'm looking for the driveshaft for a new performance super major to fit a raised PTO. I have a spare gearbox unit but missing the long driveshaft. These are specific to the new performance super major as there is a little bearing on the end of the long shaft rather than a large nut/split pin found on the earlier type of raised PTO. If anyone has one please let me know.
Thanks, Ed.
d.andersen
Re: New Performance Super Major raised PTO shaft
Post by d.andersen »
I'm pretty sure you need thr raised box too, if you want to ude the model with end bearing. I have one old model without the bearing and 1:3 ratio. And one later with end bearing but still 1:3 ratio. The correct for new performance i s 1:1 ratio. Also you need to change your hydraulic pump gear.
Fordson forever
Roadless63
Hi, I have the 1:1 box but not the shaft to go with it. I have another 1:1 complete unit on a tractor and quite a few of the earlier type.
d.andersen
Is one of them for sale ?
Fordson forever
