Just bought a Major doing some minor work to make it more usable.
Looking for a source or a part number for the gasket that goes between the rear axle housing and the hydraulic/3pt hitch. Not having any luck so far. I'm in the states if that makes any difference.
TIA.
Hydrualic Gasket
Turner85
Hydrualic Gasket
Eat more Tacos!
1957 Dexta and Major
Re: Hydrualic Gasket
Hi, welcome to the board.
Well if you can't find it, you could make your own using some gasket paper. An other option is to use liquid gasket seal like Hylomar.
