Filters for the major
Maybe it can be interesting to make a sticky post with all the type of filters used on the (super) major.
There are websites where you can cross reference between different suppliers.
So far I have:
  • Fuel Filter: Mann-filter P 810X (Type: insert filter Height: 84mm Diameter: 68mm Bore:21mm)
  • Powersteering Filter: Baldwin P183 (Type: insert filter Height: 40mm Diameter: 81mm Bore:27mm)
  • Oil Filter: 2 types 115mm high and 135mm high
  • oil bath airfilter: dimensions??
  • Hydraulic oil filter: dimensions?? 2 types exist: steel filter / paper filter
Puffie40
Re: Filters for the major
Post by Puffie40 »
I have some numbers from NAPA's filter lookup.
Napa 1188 (115mm) and 1193 (135mm) are the engine oil filters.
Baldwin equivalents are PT108-HD and PT29 respectively.
Napa 3194 is the fuel filter. Baldwin equivalent is PF816.
