following my 'Timing & tappets' topic...
I've pulled the head and taken to my engine reconditioner man. He has said get 8 new springs, valve guides & 4 new exhaust valves.
I've got various original parts books and two factory manuals. They are pretty comprehensive on the diesel motor, but details (particularly later mods) on the petrol motor are a little sketchy.
The motor I'm overhauling appears to be un-serialled, is not the original (e.g. has smaller main, fan and generator pulleys), and has definitely been worked on previously because 2 exhaust valves don't match (2 chamfered, 2 non-chamfered), and it has an odd (too small) rotator cap.
Reading the parts books it would suggest:
the petrol springs are the same as the early diesel ones, E1ADKN6513B.
the rotator caps are the same as the early diesel ones, E1ADDN6550B.
inlet collets, retainer & seal all the same.
exhaust collet & retainer the same.
The exhaust valves themselves have different numbers...
I've taken a gamble on the Agriline 'Early' kit with valves, springs, valve guides (which didn't seem an outrageous price) - if valves don't fit I'll at least have the springs and valve guides.
Now I've paid the money can someone tell me I've guffed
[I note the diesel exhaust valves also have a 'spacer' that varies over the model years. My petrol didn't have spacers, but someone had put a flat washer under each exhaust valve spring!!
