E27n back wheels locked up
Coullie
Post by Coullie »
When out driving one day all of a sudden the tractor back wheels locked up solid. Was going in and out of gears fine but was not moving . I then moved the hi/low gear stick up and down a couple of times and away it went. I think possible a ball from a bearing maybe jammed the gears. Any ideas before i split the tractor.
mauchie
Re: E27n back wheels locked up
Post by mauchie »
Nae looking like your going to get any information to help ya on this site or page , a door you must of had the handbrake on cheel lol
Timeee
Post by Timeee »
Good Day Coullie
You posted your question titled "E27N Back Wheels Locked Up" under the E27N section. I was confused by your reference to "moving the hi/low gear stick up and down". E27 N Majors do not have a High/Low Range gear lever, just the one gear lever on the left selecting 3 forward and one reverse gear. So do you have a E27N major or an E1A Major? It makes quite a difference when trying to diagnose your back wheels locking up.
Timee
/, it makes quite a difference when trying to diagnose
