Pulsing hydraulics
Bluebilly
Pulsing hydraulics
Post by Bluebilly »
I have recently had a transport box and fingerbar mower mounted on my Dexta. With the transport box in the fully raised position there is hydraulic 'pulsing' felt about every 5 seconds, dropping the box slightly stops this for a while before it starts again. With the fingerbar mower on, and the mower raised off the ground it will slowly lower itself and then raise itself up to the original height without any changes to the height setting. I use a light plastic box mounted on the arms for road runs (tools, towrope, waterproofs etc.), and have not noticed anything untoward, so it must also be linked to implement weight.
I've looked through the manual for guidance, but have not found anything leading me to the cause of the problem, which I'm assuming is linked to both symptoms. Hopefully someone here can point me in the right direction.
Ford 2000 - Pre-force
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
MF 20B - Industrial with 7 gang mower
SAME Solar 60
PghBill
Re: Pulsing hydraulics
Post by PghBill »
BlueBilly,
Is your lift control lever in Draft control instead of Position Control ?
Bluebilly
Post by Bluebilly »
Thanks PghBill, I'm overseas at the moment and will check that when I get back home.
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
