Fordson major narrow front end
dromonedog
Post by dromonedog »
Recently acquired a narrow front ent for a major and was wondering if the upper housing should be filled with oil to lubricate the two gears in there or maybe use a heavy grease. There is no level plug for this housing but there is a 1/4 pipe plug on the vertical housing and it was filled up to this plug with oil.
Re: Fordson major narrow front end
:clap: nice find. Is it the 2 wheel or the 1 wheel version? There are some drawings on the CNH parts catalog for the 2 wheeled version. It's possible you need to fill it up with oil. On the standard steering box, there's no level plug either.Let us see some pictures!
dromonedog
Not sure how to load photos
dromonedog wrote:Not sure how to load photos
Hey
You can use postimage.org or similar.
