I would like to fuse some 12V feeds but am unsure which to fuse and what rating is required - e.g. the feed to the Heater Switch. Is there a newer 'alternator' circuit diagram I could take a look at
I seem to be able to wire and feed everything OK. The lights all work. I fitted a heater switch to compliment a new fuel primer OK - both were originally missing. The new main/light switch seems OK but I notice the key does not prevent starting and would appreciate knowing what isolation switches are recommended (with public showing in mind).
Problem with the oil pressure switch - the switch stays open circuit when the engine is off
Couple of things I have noticed whilst doing the work.
1: Putting back the original heater plug was difficult as there is a pipe exiting the block right behind it. I think the heater has gone in crossed - but tight.
2: Getting the oil pressure switch out requires either a very short spanner, strong hands and steel knuckles or some sort of special spanner. I hope the new one can be socketed in.
Any help will be appreciated.
Alan
