Gaskets to do Hyd pump?
lakebilly
Post by lakebilly »
Looking to replace Hydraulic pump 63 SM & would like to get all gaskets necessary.
Kit parts #? Where? Thanks!!
63 Fordson Super Major "Babe", 1953 Jubilee, IH 656, Ford 961. Farmall H, Kubota 3430
FB pic page of tractors; https://www.facebook.com/pg/Unkle-Sonny ... 2873587074
Manta356
Re: Gaskets to do Hyd pump?
Post by Manta356 »
lakebilly
Post by lakebilly »
Thanks for info! After months in the shop, my mechanic replaced rings in pump & hydraulics seem to be working well. Just in time to put it back to work. NAPA return filter was the replacement. Leak from crack in drain plug cover is now the issue. If epoxy doesn't stop leak I will need a new cover. I have a pump that I bought on Ebay from England & it is being inspected. If all is well he will re-o-ring it & maybe I'll sell it.
Part#EIADKN-994686 is drain plug cover. I would appreciate any info on where to get one. Thanks. Much appreciation to helpers here. LB
No new ones available, so you'll need to find a second hand one and clean it well.
lakebilly
Post by lakebilly »
I expected that there wouldn't be any new ones. Perfectly fine w/one that is used & in good shape. Thanks.
