Buying flat belt pulley
Thinking of installing one. Not easy to find here. Some advertised as not turning freely.
Rebuilding seems straightforward. So if need be would buying one known to need rebuilding a decent option?
Are the belt attachments the same from the New Major to the Power and Super Majors?
We'd like to run a cordwood saw, but also wonder if this would also run an old handset circular sawmill.
It is not a Bel-saw, which were designed to run off a tractor, but a bit heavier sawmill.
Originally powered by water, likely steam and later in its life gasoline engines. I believe the last power unit was around 35 hp.
Ideally a dedicated power unit would be best, but wondering if we could use the FMD for a time milling smaller logs.
Re: Buying flat belt pulley
If they don't turn smoothly they're easy to sort. Make sure there's a circlip holding the gear on and not a nut, as those are E27N ones that won't fit. The circlip fixing was used unchanged from 1951 to 1964, so any of those would do; although if you get a chance to see a casting code it would look better if you get one that's close to your Major.
Thanks Sandy!
hazzard
Post by hazzard »
Hi leeroy, i have a pulley here for sale, came off a live drive super major gearbox, free turning in good order. Pm me if it would suit you.
This pulley will be fine.
