Dexta Engine Number
GM7PBB
Dexta Engine Number
Post by GM7PBB »
Hi, New to the forum, excellent information on here :-) We have a 1964 Dexta 09D915393 (pump P4696) but we can not figure the engine number out, the number on the flat plate normally starts with either a 14 or 16 Ours is "19B4734 C" Looked everywhere and then some to see what the engine id from or out off :-) wonder if anyone has the same engine number starting with 19.
Thanks in advance
Isle of Lewis, Outer Hebrides.
Re: Dexta Engine Number
If your Dexta is 1964, the engine number will start 15xxxxx, (16xxxxx for Super Dexta engines), the number is on a raised rectangle on the block just beneath the front exhaust manifold port. A P4696 suggests an NP Super Dexta, but this needs verifying. Some pics would help.
GM7PBB
Post by GM7PBB »
Hi. That is the engine number "19B4734 c" on a raised rectangle on the block just beneath the front exhaust manifold port. not sure how to add an image at the moment. sorry. thanks for the reply.
I think you might want to clean the area a bit better, as you might end up finding something different. There's a casting code a bit beneath the engine number but near the middle rather than near the front. It has a month letter and two or three digit number for the date and year. As for pics try this:
viewtopic.php?f=1&t=5024
GM7PBB
Post by GM7PBB »
Hi Sandy. Thanks for the help.
Other numbers on the engine are "GKN 1523" & "37111280" and a "5" in a circle.
We have looked everywhere to match the engine number with no success.
This could well be a replacement block, that number is not one I've ever seen either. Try and find [mon(0)cyl] cast on the block beneath 37111280, it's not the usual number, though, Davie has 37111310 instead. If it doesn't have [mon(0)cyl] cast on it's definitely a replacement.
GM7PBB
Post by GM7PBB »
Hi Sandy. just had another look on the dexta block, [mon(0)cyl] is there under the 37111280. the head has the same [mon(0)cyl] interesting.
overall view of Dexta
I think you have a replacement block, but I don't know of any information on what Ford stamped on them. It could be a bit like Major industrial engines that have a Sxxxxxx number, and that was what replacement blocks got too.
GM7PBB
Post by GM7PBB »
Hi Sandy. Thank you for all the info and help, very much appreciated. As you say looks like the block was replaced at some point.
Thanks again.
