Number plate light bracket.
Mervyn Spencer
Post by Mervyn Spencer »
I am short of the number plate light fitting but do have the opposit side bracket. I was thinking of tracing the bracket that I have and draw in a bulge so that when I cut out a bracket I can fit a light fitting. Any thoughts on that? Maybe the original style of light fitting is not available here at home but that rectangularfitting must be available.
Mervyn.
Re: Number plate light bracket.
Post by Jerry Coles »
I'll trace and measure my bracket. The original light fitting is still available here in the UK.
cheers
Mervyn Spencer
Hi Jerry, a copy of your tracing would be awesome thanks, I'm sure I will find a light here back home.
Mervyn.
I'm off to the Bath & West Tractor show at the end of the month, I'll see what I can find!
Mervyn Spencer
Thank Jerry,
22 Pounds plus shipping is a bit steep due to the exchange rate. We have an Autozone branch here in town I will give them a call tomorrow, our Sparex branch on the coast might have one on their shelves gathering dust I will also give them a call. Failing that Jerry I will get in touch with you before the end of the month. Thanks again.
Mervyn.
Be careful with repro lights (see this: viewtopic.php?f=3&t=6912) you can also see what the RH bracket looks like. If you need more pics I can try to take some of Davie tomorrow.
A similar lamp was used on some versions of the ‘upright’ Ford Pop, I seem to remember.
