Miscellaneous Dexta pictures
Post by Jerry Coles »
Hi folk
A pile of various Dexta pictures for you to view and make use of.
https://drive.google.com/drive/folders/ ... sp=sharing
Re: Miscellaneous Dexta pictures
Superb pics Jerry, I see you've added lots of stuff to your Dexta's over the years.
Two more added, a home made drinks holder. Made from a Baked Bean tin with the lid soldered to the side of the can for fixing to my toolbox and holes in the bottom for drainage. Spacer inside to raise the can slightly to aid access!! :)
That's a brilliant drink holder! Nice Dexta too
More added! Winch frame, Crane attachment and Cordwood saw set up. Enjoy!
And more! Tree Recovery also!
I guess you can say I use my Dexta!
Looks like it certainly earns its keep!
The Winch frame was made from some spare U channel I had. The winch is 12V and I ran a heavy duty cable from the battery to an Anderson socket fixed to a spare number plate bracket. My Dexta is -ve Earth as I have an alternator and Electronic Indicators fitted. The winch has a 50mm tow-ball adaptor from when I used it on my Land-rover Defender.
Good stuff! I find it far more satisying (and alot cheaper) to make my own attatchments and fittings. I got fed up with the narrow bucket on the JCB getting blocked up so welded a 4 inch rsj to the brackets of an old bucket and use it to make a trench for water pipes, works a treat!
Superb work Jerry.
