Fordson super 6 pot
Banagher
Fordson super 6 pot
Post by Banagher »
Afternoon all from Co. Mayo Ireland.
I am starting a new project and currently in the prep phase. The project is to build a new super major and install a 6 cylinder Thames engine.
1.
The backend is a Super major bought in County Laois, purchased approximately 1 year ago.
2.
Live drive gearbox from same source but from different tractor.
3.
6 cylinder FL engine serial S379799 sourced in Westmeath 10 years ago. It’s running. It is yellow and was taken from a combine. It still has a large pulley on the back. The simms injector has the following numbers under Simms, SPE6A755520
4.
Front Axle is a heavy duty version and has a front mounted pump with 2 hydraulic tanks and an unusual front cowl.
Two spools included. Purchased 3 years ago. I have never seen this one before but it definitely fits the front tombstone and is for a major.
5.
Duncan cab single door
Purchased in Co. Down last year.
6.
Super major hydraulic top taken from a scraper in Co. Cork.
7.
Back wheels with full Enfo weights ready to be installed. Purchased 3 years ago
So,
To begin. This project is along time coming and I have been working towards it for years. I’m always looking for bits to add to the collection.
The backend, gear box and engine are on the floor of my Garage.
Immediate plan is to bolt up back and gear box, mount back wheels and get it up on blocks. In prep for the engine part of the install I want to do some work on the engine.
I want to install the following,
new oil pump
Core /frost plugs
Sump gasket
Rocker head gasket
Water pump
Injector piping (6)
Suitable Clutch ( advise taken on what is best)
Also looking to see if anyone has drawings for modifications to the side rails and a suitable bracing for the front axle. The front axle cannot be turned around.
can anyone recommend a good source or at least the correct part number based on the Serial number above?
I apologise for the several questions I have raised but the knowledge is in this group.
I will try uploading photos and videos in the coming days/ weeks.
This project will take some time so please be patient with me and forgive dumb questions.
I have the Selene almost finished and that was a beast. The project lead has been very unwell for the past 18 months so I will update photos in that thread in due course.
Thanks in advance
Jim
Re: Fordson super 6 pot
Some casting codes would help, but your engine is an April 64. If it's running well don't do anything major to it. Using a live clutch with a six is not a wise idea, as the cover is weak aluminium (unless you intend on getting the expensive aftermarket type). Don't really understand what you mean about the front axle yet. Leave the cab until everything else is ok. Is the top cover an NP or not? What size wheels are you intending to use? New oil pumps are not available as they're different from the 4 cylinder ones (see this from Janus: https://www.tractorfan.nl/picture/886882/user/28285/). Gaskets can easily be made from gasket paper but also available pre made. Injector pipes not available. Side channels simply need the extra length, for the A frame it's worth finding or making a proper cast sump, although it will be expensive. I recommend you aim for parts to be of reasonably similar ages.
Lots of pics will be great, videos of the engine running will also be great.
Banagher
Post by Banagher »
Afternoon all,
Whilst making gaskets for the backend to gearbox I noticed that there is a pool of oil leaking out of the gearbox front the back. This is at the connection point for the pto shaft. I suspect that oil should not be leaking from the gearbox to the backend.
At this point with the gearbox on the floor, I am looking for advice on what seals/bearings should be changed on the gear box.
And if so is it a big task?
You'll need to replace the seal(s) in the PTO casting, not a hard job but the NP uses a double lipped seal while earlier tractors use two single lipped seals back to back of a slightly different size (really early Major's had a double lipped seal of the same size as the two single lip seals but seemed to fail more hence the change). This leak is a common problem, and while you have the gearbox off it's worth checking the seal on the large gear is also ok as otherwise it's a big job to fix and you've already done most of the work to check it.
Banagher
Post by Banagher »
I’m following up on the front axle comments. I have since found that the front axle came from a Whitlock Dinkum machine. The front cowl is very distinctive.
In other news, work on the backend has halted for the moment. I am commissioning a hitch manufacturer to make a pickup hitch for the super major. The backend is at the factory for measuring. A min order for 10 has to be placed and I am waiting on details of price and lead times.
Jim
There are original ones but they are expensive. They fitted on the mountings for the normal drawbar and just under the rear end of the axle casying, the lower link brackets were different as were the lift arms, and it was an independent operation setup. I think there might be pics on the forum, there's a whole section in the repair manual. The Whitlock front end will be handy for a six.
